Jack Points
Old Aug 10, 2009 | 03:53 AM
kayakman13's Avatar
Default Jack Points
I've done some searching and I can't find any decisive spots. I plan on putting my jack stands where the stock jack goes. (right next to pinch weld, on flat spot, parallel with weld) As for the floor jack, can it go on the large bar that runs across the car. Has a large flat(ish) surface that seems good. Subframe member maybe?
As to the rear, I dunno where to jack.
Old Aug 10, 2009 | 08:31 AM
Veegard's Avatar
If you look underneath, it's about directly aligned to your rear side of the front tire. There's a small boob-shaped thing bolted on, which you're supposed to use your jack with.
Of course, I didn't really figure that until I got my canals kinda twisted and bent after hundreds of jackings.
If you can't reach that point, use your canals to get it up, then get an axle stand under it at the jacking point instead, if you're gonna have it up in the air for an extensive period of time.
Old Aug 10, 2009 | 10:35 AM
Mike-2ptzero's Avatar
That would be the subframe point where the subframe brace is located. You can use that point to jack up the car, I just put my jack stands on the pinch weld but IIRC you can also use the other flat spot too.
For the rear you can just use the rear cross member spot right behind the rear diff(if you have quattro). This will lift both sides up at the same time so you an place the jack stands under the pitch welds on both sides.
Old Aug 10, 2009 | 11:32 AM
kayakman13's Avatar
Thanks mike and Veegard. Yeah, my stands aren't solid on the actual pinch. I assume thats what you mean. So I go RIGHT next to the pinch so that the stands are touching the side of it.
I usually use the boob shaped point. But with the subframe point I could get both sides in the air at once couldn't I?
Old Aug 10, 2009 | 12:21 PM
You dont want to use the actual subframe that runs under the pan to jack the car up.
Old Aug 10, 2009 | 09:47 PM
kayakman13's Avatar
!!!! WHY!? I used that!
Old Aug 11, 2009 | 12:20 AM
Because it is hollow and isn't meant to support all the weight of the front end of the car.
Old Aug 11, 2009 | 02:49 PM
kayakman13's Avatar
****! ok, well I got it off the jack and on to the stands pretty quick so I think its aight.
Rolling Blackout
Mar 6, 2009 04:14 PM
chromatin
Nov 26, 2007 07:00 PM
Scorpion
Aug 11, 2007 10:59 AM
JaceTun
Jul 20, 2007 03:14 AM
FezA4
May 9, 2005 01:24 PM
