Judder in first gear-99 2.8Q manual
Old Jun 14, 2009 | 06:47 AM
stquattro's Avatar
Default Judder in first gear-99 2.8Q manual
I changed my clutch a couple of yaers ago and all seemed to be fine until recently. When i move off in first gear i get a judder. Could this be a sign for a new clutch or flywheel?
Old Jun 14, 2009 | 07:44 AM
redline380's Avatar
Legal Moderator
not necessarily. first off, explain "judder" a little more in depth. you cant really tell when a clutch is going out until it starts to slip, which IMO is not a "judder". if it was the clutch it would happen in other gears because the clutch doesnt care which gear you are in, it just does its business. my guess would be mounts because first gear is a little tourqey, and that extra tourqe would make the tranny shutter a little. is your stick moving at all when you give it to 'er? (no that is not a sexual inuendo)
Old Jun 14, 2009 | 09:20 AM
stquattro's Avatar
Thanks for the reply.
its a vibration coming through to the cockpit inc the gear stick as i pull away in first gear. if it is the mounts is it an easy fix?
turbotodd
Aug 12, 2011 02:47 PM
rdbandkab
B7 Models
Mar 23, 2011 01:39 PM
cmccarthy
B7 Models
Mar 14, 2009 02:19 PM
aragorn65
Feb 17, 2008 08:24 PM
tbennett017
Feb 9, 2007 08:26 AM
