Just bought a '98 A4 1.8T quattro, advise me.
Old Feb 16, 2009 | 12:41 AM
captainrally's Avatar
Default Just bought a '98 A4 1.8T quattro, advise me.
I picked this up just last week and it has begun to have what seems to be a misfire at lower end of rev range, lower than 2000 revs (1500-500) When cold starting it will fire idle run rough then stall. When running it seems to lose power or lag excessively within this range when the accelerator is lifted particularly. It can often semi stall and lurch at lower revs especially when under torque loads at these lower ranges, such as a Traffic light departure or hill start. Using correct fuel car serviced less than 2 months ago including computer diagnostic etc. I've only had this thing for 4 days, I think it could be so much fun if it was running properly. Any ideas, queries, comments or theories, by all means.
Old Feb 16, 2009 | 01:23 AM
NeedanA4B5's Avatar
Member
scan it for any error codes. Could be a number of things. plugs coil pack maf etc. Sounds almost like a maf though.
Old Feb 16, 2009 | 01:38 AM
A4speed's Avatar
did you have a flashing CEL? if your misfiring its most likey the coil packs. also check plugs and stuff as well. 90%+ of the time if you have a flashing cel its bc one or more coil pack went bad.
Old Feb 16, 2009 | 02:28 AM
No bad dash lights at all, man with scan attending tomorrow.
Old Feb 16, 2009 | 02:16 PM
ghost6303's Avatar
no flashing cel= its not a misfire. you probably have a vacuum leak somewhere. check all the intake hoses, all the vacuum lines. check that your diverter valve isnt torn. also not a bad idea to replace your spark plugs with some nice NGK BKR7E's
Old Feb 17, 2009 | 08:33 PM
Interceptor's Avatar
I would start with a normal tune up and then check the maf and clean the sucker. Won't really know until the codes come back but I'm leaning towards coil packs or maf. Just an idea.. You darn turbos anyhow.
enduin
Feb 5, 2013 03:45 PM
My05Audi
Jul 3, 2012 12:04 AM
robyav
Jun 18, 2012 05:30 PM
FinmanA6
Oct 27, 2010 10:18 AM
Quattro
Aug 8, 2004 11:58 AM
