Just a few questions
Old Oct 15, 2008 | 05:32 PM
kp99audiA4's Avatar
Default Just a few questions
I am a new and proud owner of a 99 2.8 quatro. Car is amazing. Only a few peoblems with it though. One is the rer brakes are shot and need to be replaced and i was wondering if this would have anything to do with the abs going off right before you stop like a slight pulsing. The other concern is a loud front end every time you hit a large bump it is loud or sounds loose. Ive heard some talk about the control arms needing replacement any other suggestions?
Old Oct 16, 2008 | 03:30 PM
EpicWin's Avatar
ABS sounds like it's working correctly from what I can understand from your post. Check your control arms.
Old Oct 16, 2008 | 05:51 PM
kp99audiA4's Avatar
How do you check the control arms?? Also the abs goes off all the time when you are almost stopped. is this just a warning the rear pads are shot or is there a larger problem then that???
Old Oct 16, 2008 | 07:10 PM
ghost6303's Avatar
um no. the abs light should not be going off every time you brake. its probably a loose connection or wheel speed sensor or something. but no its not supposed to do that.
Old Oct 16, 2008 | 07:50 PM
EpicWin's Avatar
Where in his post does it say about the ABS light? Granted if the abs is going off at all stops, there might be an issue, but if the abs light was actually on, there would not be ANY abs whatsoever.
Now, I think we need more info from the OP.
Speak up! Tell us more.
Old Oct 18, 2008 | 03:50 PM
kp99audiA4's Avatar
Ok there is no abs light what so ever. what happens is when you are almost stopped the abs goes off. it doesn't happen all the time but occasionally it does. like I said the rears are shot andx need to be replaced. didn't know if gthis was a warning that the brakes arew low or if there iis something more wrong with the abs.
mblayton
Jan 7, 2010 07:35 PM
playboy00786
May 31, 2008 06:37 PM
zchb9
May 20, 2006 01:29 PM
portwolf
May 18, 2006 03:27 PM
VolcanicBlackA4
May 18, 2006 02:11 PM
