Just got back for the worst test drive ever!
I bought my A4 with 122k miles on it and no maintenance records of any kind. I've owned it for almost a year and had to replace the clutch, but that's it. Is there any way of telling what it's life expectancy should be if it's been very well maintained from the day I bought it?
I have no idea about Georgia, but if this happened in California, the Mexican would get released at the precinct with a court date and when he showed up to court the judge would make him pay $75 and that would be the end of it. That's called failed politics!
Really funny story though...thanks for the laugh
or isnt it?
Thanks for the warning activeautosports. Sorry, forgot to mention I later found out the timing belt, water pump, and chain assembly were all changed at 105k.
With that aside, about how many miles is a B5 A4 going to last, on average? I take great care of mine now, but have no idea about it's history prior to 122k.
Are there any ways to check for "not so obvious" abuse?
Sure take off the valve cover(s) and look at the cams and lobes for excessive wear. This would give you a slight idea of how good the oil pressure is (should be good) and if the engine oil ever ran very low for an extended amount of time. You could do a compression test too. Both 1.8 and 2.8 should last a long long time. Both should go into the 200k's before needing the head gasket replaced if they were never overheated badly. The engines are solid and should go a long long time before you need to worry about piston rings or crank bearings, etc. It's just that everything else attatched to the engine might need replaced 3 times by then
