Just ordered my low beam hids =]
Old Feb 21, 2010 | 09:49 PM
Andrew149's Avatar
Smile Just ordered my low beam hids =]
I purchased the H7 5000k hids 35watt =} $46 out the door with 2-3 day shipping what a deal!
http://www.ddmtuning.com/index.php?p...=102&parent=85
will post pics when i receive them
Old Feb 21, 2010 | 09:55 PM
ImTheDevil's Avatar
You'll love them. I'll shoot you some pics of my ballast mounting locations to give you some ideas.
Old Feb 21, 2010 | 10:02 PM
Andrew149's Avatar
okay sweet now doesnt the depo's have a mounting place? on the back of the headlight
Old Feb 21, 2010 | 10:07 PM
aledelic42's Avatar
you can mount the ballasts on the bottom of the depos if you got a slim kit
Old Feb 21, 2010 | 10:15 PM
Andrew149's Avatar
reason i didnt get the slim kit was because the more compact this **** is the more issues you will have since the solder has to be smaller which will cause more issue's
Old Feb 21, 2010 | 10:51 PM
NickBroderick's Avatar
I've had zero problems with my slim ballasts. I've had them since October. Aledelic I wish I knew about the spot for the ballasts on the headlights when I installed them! I may have to re locate...
Old Feb 21, 2010 | 11:02 PM
purpleslug's Avatar
i have a massive problem with my hids bulbs fitting right! my b5 is a 99 so it does have the face lift. the bulbs sit way to far in so the clip cant even hold them in any sugestions or did i order the wrong bulbs?
Old Feb 21, 2010 | 11:20 PM
Andrew149's Avatar
http://www.sylvania.com/ConsumerProd...de/default.htm
do that guide and it will tell you what you should of ordered
Old Feb 22, 2010 | 10:42 AM
bradtyler02's Avatar
The face lift happened on the 99.5, you need to know which one you have...
Old Feb 22, 2010 | 01:33 PM
Andrew149's Avatar
if you have 99.5 put in 99 if you have a 1999 put in 98
