k04 install CEL'S
Old Oct 2, 2010 | 05:28 PM
swinburn15's Avatar
Default k04 install CEL'S
So today I finally finished my k04 install on an 01 Audi a4 1.8T. Installed the GIAC tune with new injectors and 3" MAF. Started right up and runs fine. Boost is a little lower than expected but I think thats from the spring in the DV. However, my check engine light is on which I need to get scanned. But also the ABS light and Electronic Stablility Program light is on. Anyone have any idea as to what that could be?
Old Oct 2, 2010 | 06:22 PM
joenelson7687's Avatar
Hmmm...might have the check the codes first. I'm taking a shot in the dark and saying it has something to do with the GIAC tune you have...not saying its bad or anything, but that's certainly a possibility. When you say that your boost is lower than expected, what psi are you peaking and settling at?
Old Jan 26, 2011 | 02:29 PM
swinburn15's Avatar
boost peaks around 14 lbs and holds for awhile then will drop to 10-12. had the cel scanned and it came back as the maf leaking air and then was told it was running rich/lean..forget which one. installed a high flow cat and having the same problems
Old Jan 26, 2011 | 03:41 PM
dragonrage's Avatar
Boost leak? Bad front O2 sensor?
Old Mar 29, 2011 | 08:31 PM
swinburn15's Avatar
don't think I have a boost leak, however had the ecu scanned again. Still have a leaking MAF. Went over my intake still same problem. Also threw a code for bank 1 so im assuming my front o2 sensor went bad.
Grey2007
Feb 23, 2012 01:17 PM
kevinbednarek
Feb 22, 2012 06:19 PM
Brautty
Jan 21, 2012 12:38 AM
Dave666
Jul 12, 2005 08:47 AM
1996a4
Apr 4, 2005 04:09 PM
