k04 question.....
Old Oct 30, 2009 | 05:31 PM
carbonOX's Avatar
Default k04 question.....
Does the k04 bolt up to all the 1.8t stock stuff?? After I get my fuel pump and filter I was thinkin about getting a chipped ecu and a different turbo. Bassically want to slowly build up this car. I would like to go big all at once, just dont have that kind of extra cash to be droppin on it. Also does anyone have any suggestions that pull extra horse out of a 1.8 cheaply?
Old Oct 30, 2009 | 05:35 PM
ghost6303's Avatar
read the stickies, they cover this topic in depth. and yes the k04 is a direct bolt on replacement for a k03, you can even run it on the stock software (though you wont get the extra HP without a tune).
Old Oct 30, 2009 | 05:38 PM
carbonOX's Avatar
but i did see a chipped ecu that would kick out up to an extra 70 hp. I need to switch out my stock dv too
Old Oct 30, 2009 | 06:35 PM
codymack43's Avatar
lol this is the third time today that i've said it... READ THE STICKIES!!!
It'll tell you everything you need to know about mods and everything. The threads are for more specific questions.
You can also find a LOT of info by using the search feature.
Old Oct 30, 2009 | 08:22 PM
gaberossi's Avatar
direct bolt on....you def want to get all the other supporting mods though, they help ALOT.
Old Oct 31, 2009 | 03:44 AM
carbonOX's Avatar
ya I went through the stickies. I guess when I am ready to do anything I will just research it all before
Old Oct 31, 2009 | 01:17 PM
RockyMountainB5's Avatar
I think any tuning company claiming 70hp from a new chip is exaggerated.
On 91 octane gas, you will get about 20hp from getting it chipped (with no other mods)
Old Oct 31, 2009 | 01:26 PM
ghost6303's Avatar
APR, GIAC, Unitronics etc all add about 50hp and 50tq. that is probably crank HP not wheel HP, but you get more then 20hp from a chip. 70 is only slightly exaggerated. the only thing you need with a chip is a better DV.
Old Nov 7, 2009 | 05:14 AM
gaberossi's Avatar
70 is reachable...i have a problem with my wastegate so once in a while i get a 30psi spike then it holds 25-26psi all the way to 5900rpm then drops to 22 and stays...but we had 232hp but 320lbs of torque on the dyno with that wastegate problem, but normally when the wastegate decides to "behave" it holds at 22-24psi(temp depending) pushing 274lbs of torque, this is with a uni file but with a custom tune on 93 but it runs great with race gas...and i am FWD with everything as stiff as it can be in the drive train and axles
Old Nov 7, 2009 | 04:49 PM
carbonOX's Avatar
ya, but I imagine you cant get those kinds of psi levels out of a little k04
