K04 turbo upgrade, which software is best?
Old May 8, 2011 | 12:48 PM
Mike-2ptzero's Avatar
Originally Posted by shortyxc
I thought the stock FPR was a 5 bar? correct me if I am wrong. And intercooler required for a K04? I am not sure i would say that you need one. It may help with heat soak some, but that turbo doesn't seem big enough to actually "need" one. I think you would be fine with the PC16 without an intercooler, unless they won't tune it. just my 2 cents.
The stock FPR is 4 bar. Down side to going with a 5 bar is it causes the fuel pump to flow less fuel.
PC 16 needs an upgraded intercooler because it pushes the K04-15 at high boost levels which means the turbo is going to be pushing out air at very high temps. High flowing exhaust should also be used.
Fact is that a upgraded intercooler should be used even on a standard K04-15 setup or even on a chipped K03. Even a chipped K03 is going to have air coming out of it that is very high in temps. The stock SMIC was really designed for low boost like the stock tune runs.
Old May 26, 2011 | 01:48 PM
shortyxc's Avatar
Ahh that would make sense. Thanks Mike.
AudiCabroNotts
Apr 10, 2013 03:37 AM
JeffKW
B8 Models
Dec 8, 2009 01:28 PM
TTsteve
Jun 1, 2007 11:48 PM
sdkaliman
Nov 23, 2005 10:06 PM
prodrive
Oct 12, 2005 05:23 PM
