knocking noise coming from engine
Old May 23, 2010 | 10:33 PM
whtturboa4's Avatar
Default knocking noise coming from engine
hey i have a knocking noise on start up and when the engine is at opperating temp. and the noise is coming fromthe back of the motor. i have an 01 1.8t. if anyone has any advise for me i would really like hearing from you thank you.
Old May 24, 2010 | 12:06 AM
bradtyler02's Avatar
Scan for codes and post them... you're more likely to get some good advise that way.
Also, not to insult your intelligence, but check your oil.
Old May 24, 2010 | 01:46 PM
dragonrage's Avatar
Could be the cam chain tensioner. Could be many things, though.
Old May 24, 2010 | 08:54 PM
Pjbrof's Avatar
could be a lifter, have you tried thicker oil?
Old May 27, 2010 | 05:44 PM
jokeabus's Avatar
Probably the cam chain tensioner. Mine just went up the other day.
Old May 27, 2010 | 07:12 PM
chocalotstarfish's Avatar
Super Moderator
I have a constant tick/knock in my motor...
Old May 27, 2010 | 10:52 PM
kayakman13's Avatar
Use a stethoscope to pinpoint the sound's location. I had a knocking everyone (mechanics included) swore was rod knock. I poked around with the scope and found it to be a loose power steering pulley.
Old Aug 6, 2010 | 11:10 AM
whtturboa4's Avatar
well I have been poking around with sethoscope and found the knocking coming from the rear of the motor like where the cam chain is at. I have pulled codes and I'm getting a code for an advanced cam and intake air circute to low. I have also tried thicker oil but nothing seems too make the knock quiter or any good results.
Old Aug 6, 2010 | 11:44 AM
onepoint8tee's Avatar
Have Fun!
All VW's have slightly noisy lifters. There is a big difference between a little vw knock/tap and a bad cam chain tensioner. If your oil pressure was low enough to keep oil from getting to the top then you'd likely have a oil pressure light.. You could check your oil pressure first to be sure, though.
Old Aug 15, 2010 | 09:31 PM
whtturboa4's Avatar
ok i have checked my oil pressure and i got 40-60 psi. so im getting good oil pressure. but the only thing is that the knocking noise happening when i first start my car when its cold and it happenes when my car is at operating temp. so im thinking its the cam chain tensioner.
