to kriptonik, kayakman and drangage
Old Mar 22, 2010 | 04:48 PM
  #31
zakario's Avatar
dude with the huge truck has a tiny wiener
Old Mar 22, 2010 | 04:59 PM
  #32
CCA4's Avatar
meant to ask, did you end up bein able to get them out without takin the bumper off?
Old Mar 22, 2010 | 05:09 PM
  #33
Mr. Phil's Avatar
yea icouldnt even figure out how to take the bumper off haha
Old Mar 22, 2010 | 08:42 PM
  #34
airguard350's Avatar
Tech Guru
The front bumper? After you unclick the sides (they come out real weird) take out the center grille (just yank it out) and look up from the ground. You'll see two hex lag bolts; they're 6mm and about 12 miles long. Unbolt and pull bumper off.
Edit: When I put the bolts back in they didn't seem to thread into the urethane on the snub mounts. I used teflon thread tape to make them grab and hold.
Old Mar 22, 2010 | 08:49 PM
  #35
CCA4's Avatar
they did seem a bout a mile long didn't they? lol. glad to hear you had an easy time swapping the headlights Phil, IMO they look much better, and i'm sure you'll see better as well
Old Mar 22, 2010 | 09:19 PM
  #36
Mr. Phil's Avatar
yea ive noticed the one headlight that works is a biiig difference in where it shines... it doesnt seem as blueish either lol
Old Mar 22, 2010 | 10:46 PM
  #37
Mr. Phil's Avatar
here is the pic... i got my d2s kit in the mail today... but no d2s adapters lol... so i have to wait.... anyways i found the other balast connector thing.. it was inside the light housing hahaha... here is a pic of the lights and cut off thing
how do u adjust the lights? like from left to right? and how far away are u supposed to be when u adjust the lights
Old Mar 22, 2010 | 11:22 PM
  #38
kriptonik's Avatar
They look good Phil!
Give the a car a touch of more updated look.
Old Mar 22, 2010 | 11:30 PM
  #39
Mr. Phil's Avatar
what u mean give the touch of good luck?? and do u know how to adjust them?
Old Mar 22, 2010 | 11:38 PM
  #40
kriptonik's Avatar
Luck? I said look.
On the Valeo ones (not sure about yours but it should be similar) there should be a white colored tube behind each of the headlights. You'll see that there's a part where you can adjust by putting in a hex wrench or a screw driver.
There should be two of these tubes on each headlight. One for the high beam and one for the low beam. Make sure you adjust the right one.
