leaking water
Old Oct 24, 2010 | 12:25 AM
Theghost_85's Avatar
Default leaking water
for some odd reason my car is leaking water in the passenger side of the car and the battery compartment, anyone have any good ideas about this
Old Oct 24, 2010 | 12:31 AM
B5 Audi's Avatar
could of posted all your problems in one thread.
Old Oct 24, 2010 | 12:49 AM
my bad first time using this
Old Oct 24, 2010 | 01:15 AM
Andrew149's Avatar
there was an actual recal for this i would call the dealer and ask about this
Old Oct 24, 2010 | 08:21 AM
Oh **** good look cause it looks like a nightmare to fix
Old Oct 24, 2010 | 01:49 PM
twoeightquattro's Avatar
is the water in the cabin? passenger side floormats and what not? this happened to me a while ago. my problem was a clogged A/C drain, which made it leak out of the vents and got the carpet all wet and what not. just had to find the drain, a little compressed air and boom. fixed
Old Oct 25, 2010 | 11:50 AM
4bagels's Avatar
if it's leaking inside AND you saw standing water in your battery compartment, it's probably an easy fix. Remove the battery, remove the battery tray, and you will see a small rubber drain directly underneath where the battery was. It's probably plugged up with leaves and gunk. Just clean that out, and clean up any junk in that whole cowl area.
Some say it's best to simply remove that rubber "one-way-valve" from the drain. I left mine in there for now, and just keep that area clean. So far it's been ok since I had a situation like yours.
Old Oct 25, 2010 | 02:33 PM
thanks guy i wouldnt know what to do with out you
RobinJ
May 2, 2014 11:03 AM
Theghost_85
Nov 18, 2010 05:43 PM
rmA4
Jun 12, 2010 12:13 AM
audimasher187
Jan 7, 2008 10:01 PM
4Wheelin
May 16, 2006 11:10 AM
