Leaky a pillar
Old Apr 16, 2013 | 06:42 PM
rmr1499's Avatar
Default Leaky a pillar
Ok so my driver side a pillar is leaking its not the window I have the trim off and it's actually coming from inside the a pillar itself and dripping onto dash. Not the sunroof drains cause I just pulled the 2 in the rear and cleaned them last weekend
Old Apr 16, 2013 | 06:53 PM
sincityaudi's Avatar
There are two front sunroof drains that get clogged and the water runs along the sunroof frame down the pillars. The only other option, if there isn't body damage, is the sunroof seal itself is damaged
Old Apr 16, 2013 | 07:19 PM
rmr1499's Avatar
Where are the 2 fronts I only thought there were 2 backs
Old Apr 16, 2013 | 09:01 PM
mtroxel's Avatar
No there are front ones too. They come right down the A pillar and out the door jamb.
Old Apr 16, 2013 | 09:51 PM
Skythe's Avatar
Could be your windshield seal leaking. Same thing started on mine too and my sunroof drains aren't blocked
You can access the front sunroof drains from the top by either opening the sunroof window or removing the window; then follow the diagram above for the door jam grommet.
Old Apr 17, 2013 | 08:00 PM
jeckel20003's Avatar
I had a leaky C pillar. Turned out the hose that goes onto the sunroof drain had somehow come off and the water was running out the drain and down the pillar. I was able to pull the headliner down far enough to get the hose snapped back on the drain. I haven't had any problems since then.
Old Apr 19, 2013 | 06:19 AM
rmr1499's Avatar
Cleaned the front and rears now I wait it suppose to rain today so we will see how it goes
vellomike
Sep 13, 2009 09:05 PM
lyndoman
Aug 14, 2008 11:30 PM
lyndoman
Oct 3, 2007 10:16 PM
AudiCross
Aug 20, 2006 11:30 PM
A6 newbie
Jun 5, 2006 02:46 AM
