LED H7's
Old Mar 14, 2012 | 03:24 PM
vgo's Avatar
vgo
Default LED H7's
Anyone ever try one of these?
2X Car Auto Light Lamp Bulb 120 LED 3528 SMD H7 Xenon White Fog Driving Head 12V | eBay
Besides the 120 LED's, there are also 68 LED's H7 available. I would think 68 may not be enough. This is only going for less then $10 a pair, with free shipping.
My question is, this may throw an error on the dash, and I've read that it can be fixed by putting in the right resistor. How would I place the resistor in the circuit? Before the bulb, or After or across the leads?
Old Mar 14, 2012 | 08:06 PM
theflash's Avatar
I can't recall how much resistance you need, but it would be in series. I notice that link says the bulb is 500 LM. If that's Chinese for lumens, that is seriously low. A 55w Halogen produces around 1500 lumens... a 55w HID is around 3000 to 3500 lumens...so these bulbs would be okay for daytime running lights but will provide less light than cheap walmart foglights.
There are hi-power leds that provide 200 lumens each, but those are made by higher end companies such as luxeon.
Old Mar 15, 2012 | 07:50 AM
vgo's Avatar
vgo
Thanks for the info. I wasnt sure what would be considered low lumens for lowbeam application. I know ecs is selling LED reverse lights (way too expensive, ebay have others go for cheaper), so I started searching if I could do a full LED conversion for the rest.
Old Mar 15, 2012 | 01:42 PM
ou2mame's Avatar
i don't think LED's are there yet for headlights. i considered it but after a minimal amount of research, i went with an hid kit instead. its cheap and effective.
Old Mar 15, 2012 | 02:25 PM
vgo's Avatar
vgo
I'll probably buy a set for foglights. I'll see if I can get a set in yellow and I'll post up some pics if anyone else find interest in this.
Old Mar 15, 2012 | 02:30 PM
MetalMan's Avatar
In case somebody does try this, they'll want the resistor(s) in parallel to keep the car from thinking a bulb is burnt out. Putting in series wouldn't do the trick and would limit the voltage to the LED bulb. When you wire up a single LED then you want a resistor in series.
Old Mar 15, 2012 | 07:03 PM
theflash's Avatar
You're right. My bad.
