Lefts lower then the right?
Old Feb 14, 2008 | 12:34 PM
Babz's Avatar
Default Lefts lower then the right?
Ive got a 1997 Audi a4 1.8t quattro , manual and my car is dropped towards the front left quite a bit. My lower control arm(s) on that side has been sqeaking a bit and i just got a wheel alignment done last week. Has notfelt right since. Just wondering could it be the bushes or something to do with the wheel alignment??
Old Feb 14, 2008 | 12:44 PM
96A4Owner's Avatar
Default RE: Lefts lower then the right?
When I tore the ball completely out of the joint, my entire wheel was pushed forward and was rubbing on my fender wall.
Old Feb 14, 2008 | 08:26 PM
ImTheDevil's Avatar
Unless it's just a weak spring (which is possible) you should be able to jack up the car, remove the wheel, and probably find something in there that is damaged or broken. The cause of that dramatic a difference should be apparent.
MikeSpock/AWE
Apr 17, 2015 04:28 PM
Andrew/AWE
B8 Models
Feb 7, 2013 10:56 AM
Andrew/AWE
Feb 7, 2013 10:54 AM
cruciform
Oct 11, 2010 03:54 PM
wolfe2118
Jun 25, 2008 07:09 PM
