lets try this again. "Service Insp." light
Old Apr 13, 2009 | 03:24 PM
superdooperme's Avatar
Default lets try this again. "Service Insp." light
when i start up the car, i get a flashing "service insp." light where the odometer reads.
1st, no its not the service oil light. i had that before and followed the DIY on resetting it and it worked fine.
tried the same procedure for this light with no affect. tried both versions for resetting it for the pre 99 and then the newer model version.
is this something i can only reset with a Vag-Com scanner?
i want it to go away
Old Apr 13, 2009 | 03:52 PM
turbo kraut's Avatar
Tech Guru
never had that light.... sorry
Old Apr 13, 2009 | 04:06 PM
hmmm...
could it be just a light to tell me its time for my 130,000 mile tune up or sumthin?
or do i have a problem... lol
cause i also have the airbag and abs light on
Old Apr 13, 2009 | 04:17 PM
ghost6303's Avatar
its an indicator that comes on after a set number of miles. you are supposed to bring it to the dealer to have a regular inspection when that light comes on, then the dealer resets it. it is not a CEL or a MIL. the only thing that triggers it is mileage.
Old Apr 13, 2009 | 05:48 PM
vgo's Avatar
vgo
i have that light on too...im just gonna leave for now.
Old Apr 13, 2009 | 06:19 PM
Tech Guru
those answers are probably right, but like i said i have never had that light
i did have the airbag light and have the abs light, gotta fix my modual
Old Apr 13, 2009 | 11:26 PM
Mckayiva4's Avatar
I have that "insp" light too. Is the dealer the only one who can turn it off?
Old Apr 14, 2009 | 12:16 AM
auditech79's Avatar
I think you need to drive to the dealer, and buy an owners manual.
Old Apr 14, 2009 | 12:20 AM
i have a manual
i just dont like paying at least $130 per visit to the dealer so im tryin to avoid that if possible
Old Apr 14, 2009 | 12:27 AM
auditech79's Avatar
There is only one "service" light programmed into that cluster, so if you can't figure out how to change it the old fashioned way, the vag com can easilly erase it for you. There is a option for SRI reset. If you plan to DIY at all down the road you need a vag com any way so, go ahead and invest in one.
