Little help with drivers seat issue
Old Jun 24, 2008 | 12:24 AM
Tweaked's Avatar
Default RE: Little help with drivers seat issue
, you can put the end of the cable in the drill and slowly turn.
Tweaked's Avatar
It usually damages the cables though or can **** the seat in the track.
Old Jun 24, 2008 | 12:25 AM
Tweaked's Avatar
With the cables detached from the motors, I think you should be able to move the seat...
Tweaked's Avatar
will somebody please fix this thing?
Old Jun 24, 2008 | 11:08 AM
nflea7's Avatar
Tried that, the seat won't budge with me pushing on it with out the motor in, one other thing I thought of is to take the good motor that moves the seat up and down and swap it in place to get the seat to move. Thanks Tweaked for all your help
Old Jun 25, 2008 | 10:17 AM
Tweaked's Avatar
you could try that, as long as there's enough room to swap the motor. It just has to move enough so you can unbolt the seat, so that sounds like a good idea.
Old Jun 25, 2008 | 12:33 PM
nflea7's Avatar
The thread can close! I finally got it last night. I unbolted the next motor up and un did the wires enough to get it to the back spot that moves the rails and hooked it in and it moved the seat back so I could un bolt it. Then I proceeded to tear the whole thing down and replace the seat cover with a non riped one, fix the broken seat heater wire and re bolt up all the motors under the seat with great success, the motor that moves the back tilt is now my forward back motor but the front one still works so its a 2 way seat instead of a 3 but it works! Thanks for the help Tweaked
rwb
Jun 24, 2013 01:05 AM
ouijacom
Jul 20, 2010 05:44 PM
cipha
Sep 22, 2008 04:00 PM
sandnsnow24
Dec 12, 2005 07:03 AM
