Locks do not work after changing battery in car (not by FOB, or by buttong in car)
Old May 26, 2014 | 02:28 PM
normal's Avatar
Default Locks do not work after changing battery in car (not by FOB, or by buttong in car)
Hi - let my 98.5 a4 2.8 sit a while over winter without using it. then replaced (car) battery this spring. Since replacing battery, my locks do not work. They don't work at all, not by FOB or by buttons in the car. I can lock/unlock drivers door by using the key, but truck and other doors do lock/unloc.
I don't not have a vag com. Can anyone help me try to get locks working again?
Old May 26, 2014 | 08:52 PM
markymarc's Avatar
Drive it for a few days and they will work again.....basically, your locks on your 98 are vacuum controlled. If you leave it sit and don't use it, OR disconnect the battery for a period of time, they lose vacuum. If you drive it a few days or for some time....they will work again.
Old May 27, 2014 | 06:43 AM
bradtyler02's Avatar
Have you had to fill up yet? The fuel tank door operates on the same system as the door locks. If you stick your year near the cubby hole on the passenger side of the trunk, you should hear the little motor whenever you press the lock or unlock on the key fob.
Old May 27, 2014 | 08:36 AM
normal's Avatar
Hi - this is great to hear!. Do you know if it is simply a function of time and driving, or , is there anything that will speed up the process (like pressing the locks repeatedly)?
thanks for your post
Old May 31, 2014 | 10:46 AM
normal's Avatar
bump bump
Old May 31, 2014 | 10:57 AM
markymarc's Avatar
Originally Posted by normal
bump bump
Still not working?
Old Jun 1, 2014 | 12:44 PM
normal's Avatar
no, not yet. although I haven't been daily driving it yet either.
Do you know what makes it (hopefully) build vacuum up again? (running time, pressing lock button, starting vehicle, ??)
Old Jun 1, 2014 | 01:22 PM
Is the pump running or not? When I had to repair mine, it started working immediately. Pressure or vacuum did not need to build up over time.
Old Jun 1, 2014 | 04:42 PM
normal's Avatar
OK went out and tried it again. Here is what I did/observed:
- checked central locking fuse and it was fine
- tried pushing lock button: heard and 'electrical click' which seems to come from back right (pump) area, but did not hear the pump run.
- I do now recall that locks (pump) had been a bit delayed (pump ran longer) when they last worked.
- I also believe that the 'electrical' part of the central system must be working fine because: 1) the horn chirps if I hit the lock button on my remotes and 2) I observed that click sound when sitting in car and hit lock button and 3) the little red light by driver lock appears to arm/disarm as normal when I'm outside vehicle and use FOB to arm(lock)/disarm(unlock) (even though lock do not actually move)
So, at this point I'm assuming my pump must be the culprit. NEW QUESTIONS:
- Are there any domestic USA options for rebuild parts for the pump? I've found a guy on ebay that offers parts, but he is not in usa an it seems a bit spendy.
- If I opt for a used pump, will it be plug and play or will it require any programming type complications to make it work?
- Any other suggestions/options?
Old Jun 1, 2014 | 04:44 PM
normal's Avatar
see updated post for more detail, but no I don't think it is running.
how did you repair yours? any suggestions for rebuild parts/kit?
