looking for adviceon 96' a4 quattro
Old Aug 5, 2009 | 08:34 PM
Soup's Avatar
Default looking for adviceon 96' a4 quattro
my car is f'ed
looking used parts and how to help fix cek and other stuff
P0102, p0103 - mass or volume are flow circuit low input
p0116 - engine collant temp range performance
p0122 - throttle/ pedal position sensor A circuit low input
p0141 - 02 heater circuit bank 1, sensor 2
p0158 - circiut high voltage bank 2 sensor 2
noticeable probs include low pwer(car has no power above 4000rpm) car occasionally stutters under acceleration (cek does not blink) car constantly dumps coolant into the resevior i have tested to see if it was the head gasket and car did bubble a little bit throughout the entire 10 min (every min or so 1 or 2 bubbles). rear passenger window, sunroof and power locks dont work. also driver side tie rod squeaks and side veiw mirrors are rusted coolered
should i bother fixing?
thanks
Old Aug 5, 2009 | 08:59 PM
ObnoxiousDrunk's Avatar
I believe you have two codes which pertain to O2 sensors. Those you can replace yourself. Rear passenger window could be a motor or regulator, which as long as you have the time is a cheap do-it-yourself. Not sure about the sunroof or power locks but it doesn't sound like you should commit your car to the graveyard just yet.
You can find all the how-to's online, all you need is the proper tools and the will to do-it-yourself.
Old Aug 6, 2009 | 07:31 PM
Soup's Avatar
is it possible to install 01 b5 a4/s4 side mirriors on pre-facelift 96 a4
ypcyrl
Dec 13, 2013 09:50 PM
