Loose Parking Break
Old Apr 20, 2009 | 08:29 AM
hendrix1313's Avatar
Default Loose Parking Break
I've been searching around, can't find anything. I practically pull the parking brake through the sunroof to get the car to stay. Can I adjust the cable tension from inside the car? Please let me know what you guys think, I figured this would be a really easy job. Thanks
Old Apr 20, 2009 | 09:18 AM
hiwords's Avatar
well first check the rotors and pads. i think there's a adjuster under the car, but i'm not sure exactly where, to adjust the tension of the cable.
Old Apr 22, 2009 | 11:03 AM
Isn't the parking brake separate from the hydraulic brakes?
Old Apr 22, 2009 | 12:48 PM
The Bishop's Avatar
Yes. You have to adjust the cable at each one of the back brakes. Just take the wheels off that tighten the cable adjuster nut. Be sure to check to see that you have a good amount of brake pad left, and this isn't just a sign that it's time to replace the pads.
Old Apr 22, 2009 | 06:22 PM
never_enough's Avatar
i seem to recall reading in my haynes manual that the adjuster is somewhere in the exhaust tunnel. let me know where you find yours because mine could use some adjusting too.
Old Apr 22, 2009 | 11:54 PM
ghost6303's Avatar
even if your rear pads were gone or if they were brand new, the handle should still travel the same distance because the ebrakes are self-adjusting. the cable itself might have stretched over time and there is an adjustment for that, but the breaks themselves auto-adjust for pad wear.
Old Apr 23, 2009 | 02:00 PM
does anyone know exactly where the cable adjustment is?
Jack_Tauson_Sr
B8 Models
Oct 3, 2014 04:05 PM
Airmantony
Jun 11, 2014 09:47 PM
Leslie
May 22, 2013 08:44 AM
BigKidFun
Jun 3, 2011 07:06 AM
ReX
Jan 21, 2007 07:35 PM
