Loud Whistle Under Boost
Old 04-21-2014, 10:42 PM
adam044's Avatar
Default Loud Whistle Under Boost
Ever since I got the car I get a very loud whistle when I boost. It's only seems to be at full boost (10-12 PSI) I'm not sure if it just the turbo or a boost leak or something else completely. I seem to hold PSI fine so it doesn't seem like a boost leak but shoot me some ideas on what it could be.
Old 04-22-2014, 10:21 PM
redline380's Avatar
Legal Moderator
your turbo is going out
Old 04-23-2014, 10:22 AM
swimbikerunrun's Avatar
Do you have a boost gauge?
..which tune does 10-12psi?
Old 04-23-2014, 11:32 AM
adam044's Avatar
Yes, Speed Tuning USA, why?
Old 04-23-2014, 06:26 PM
Pbcrazy's Avatar
I'm assuming he's asking because most tunes will run between 15-18, not sure why speed tuning is so low.
Old 04-23-2014, 06:37 PM
adam044's Avatar
A lot of people recommended them. It was $199 compared to other companies which run $400+. Same HP and torque gains just less boost.
Old 04-23-2014, 08:05 PM
Pbcrazy's Avatar
Doesn't work like that. Two good quality stage 1 tunes for a k03, one running 18psi and one running 12psi the 18psi will win. I'm wondering if you have a vacuum leak or similar somewhere. I can't imagine a tune only going from the stock 7psi to 12psi
Old 04-23-2014, 09:11 PM
adam044's Avatar
I contacted multiple companies and the HP and torque gains were almost exact. So I don't know what to tell you.
Old 04-23-2014, 09:14 PM
Pbcrazy's Avatar
I know, that's why I'm saying you might have a vacuum leak. It could also be your turbo is getting bad and it isn't building full boost (16psi+)
Old 04-23-2014, 09:18 PM
adam044's Avatar
Possibly, I believe I do. How do you recommend doing a boost leak test? I've only done them with pressurizing the system but my friends air compressor is broken right now so that won't work, in my opinion that is the best way to do them.
Or maybe the turbo is bad and if that's the case well oh well 12 PSI works.
Quick Reply: Loud Whistle Under Boost
