Low rpm bucking
Old Jun 21, 2009 | 09:31 PM
TheBat's Avatar
Default Low rpm bucking
When my 97 2.8 is cold it bucks a little. It also doesn't seem to have the power it should. I got 0174 and 0171 codes a few weeks ago but they haven't come back. I've swapped the maf, checked for vacuum leaks. Not sure when the fuel filter was last changed....
Old Jun 21, 2009 | 09:58 PM
hiwords's Avatar
seafoam the car and check your plugs
Old Jun 24, 2009 | 07:04 PM
markcm's Avatar
I had low rpm bucking at about 30mph, it turned out to be plug wires. I vag'd it and found misfires so I swapped some wires around and the misfires followed the wires. Changed the bad wires and good to go now.
Old Jun 25, 2009 | 06:57 PM
TheBat's Avatar
Its been seafoamed and the plugs are new. It doesn't feel like an ignition buck, feels more like a lean surge/buck.
The fact that it does it worse sometimes when its cold means that it does it even in open loop right? The vag-com shows a rough engine torque.
I'm not sure how to check fuel pressure, but could it be a restricted fuel filter? I don't know when it was changed last, if ever.
pestto
Nov 17, 2013 08:14 AM
psebra
Nov 26, 2010 10:26 AM
audi2000
Aug 27, 2009 12:49 PM
michaelm
Feb 17, 2009 02:10 PM
danstr1
May 2, 2008 10:59 AM
