bucking audi
Old Nov 16, 2013 | 12:00 PM
pestto's Avatar
Default bucking audi
hello, I have an 98 a4 quad avant 2.8 trip auto, lately I have had some issues w/ the car bucking in 4 and 5 gear sometimes in 3rd when I hold the throttle at a steady pace the rpms go up and down and the bucking happens no issues from a dead stop gears 1 & 2 but the others is when this happens is this a trans issue or another issue I changed the plugs and it still happens I also took it to advance auto & auto zone for a code read and both times the scanner would not connect to the car Any help is appreciated. Thanks
Old Nov 16, 2013 | 12:55 PM
Kamil`'s Avatar
Another member had stated on another thread if you have an aftermarket radio installed you might need to disconnect in order to plug up a OBD-2 device to the car.
I don't know if its transmission related, but hopefully not. If it is, your looking into a big investment. If its not, you will probably get by replacing a sensor or solenoid here and there.
Old Nov 16, 2013 | 01:29 PM
pestto's Avatar
yes kamil it does have an aftermarket radio i'll look for that thread thanks.
Old Nov 17, 2013 | 08:14 AM
M5S5's Avatar
Tech Certified
Disconnect the radio first. A improperly installed radio will fry a scan tool. It sends power to the communication line.
AudiChristina
Jan 8, 2013 08:32 PM
audi2000
Aug 27, 2009 12:49 PM
TheBat
Jun 25, 2009 06:57 PM
danstr1
May 2, 2008 10:59 AM
sinisterkaraudio
Apr 6, 2008 08:29 PM
