lowering the B5
Old Jun 23, 2010 | 02:58 PM
gDmM@NnY's Avatar
Default lowering the B5
ok so i have a B5 12v and im looking to dropping the car around 2 inches with out having to spend hundreds on coilovers.
is it possible to install 1.8t springs on my 12v to get that look?
pros and cons?
Old Jun 23, 2010 | 03:09 PM
bradtyler02's Avatar
Springs on stock shocks are a bad idea, especially with old shocks.
The 2.8 is heavier than the 1.8T, the front end will sit lower than expected on 1.8T springs.
The suspension is different for the quattro and FWD, so keep an eye on that.
Spring and shock kits- about 800 bucks on ecstuning.com/ V-maxx coilovers, about 750.
Old Jun 23, 2010 | 03:23 PM
gDmM@NnY's Avatar
but will it work?
Old Jun 23, 2010 | 03:28 PM
I suppose, but if your 2 inch drop turns into a 2 and a half in drop because of the extra weight, you'll probably start rubbing pretty bad.
Old Jun 23, 2010 | 03:33 PM
gDmM@NnY's Avatar
what springs would u recommend then
Old Jun 23, 2010 | 03:42 PM
Whichever ones are least expensive, I guess, since you're going to have to replace the entire suspension shortly thereafter if you put the springs on the stock shocks. NeuSpeed makes a "race" set with about a 2 inch drop.
Old Jun 23, 2010 | 03:44 PM
gDmM@NnY's Avatar
im gonna change the shocks in 2 months or so
Old Jun 23, 2010 | 03:52 PM
You would be better off waiting those two months and buying a complete kit then, cheaper in the long run. Are you quattro or FWD?
Old Jun 23, 2010 | 03:58 PM
gDmM@NnY's Avatar
fwd. cheaper how tho? im looking to be super slammed. i just want to close the wheel gap
Old Jun 23, 2010 | 04:02 PM
gDmM@NnY's Avatar
im not*
