Lug pattern help searched
Old Nov 8, 2008 | 05:36 PM
kp99audiA4's Avatar
Default Lug pattern help searched
I searched and found that are cars have the 5x112 lug pattern. will a 5x100 or a 5x114 fit our cars? Thanks
Old Nov 8, 2008 | 05:48 PM
ImTheDevil's Avatar
No. Our car is 5x112. That's what will fit.
Old Nov 8, 2008 | 05:53 PM
ghost6303's Avatar
infact a square peg does not fit in a round hole.
Old Nov 8, 2008 | 06:00 PM
Sidewayzracer's Avatar
unless the peg is small enough itll fit
Old Nov 8, 2008 | 06:43 PM
AutoUnionFan's Avatar
5x112 - 5 bolts located on a circle with diameter of 112mm. Meaning that the center of each bolt is 56mm from the center of the wheel. GOOGLE was invented for a reason.
Old Nov 8, 2008 | 06:49 PM
CAB509's Avatar
6th Gear
anything you want can fit on your car, it just depends on how much you want to spend?
I'm sure you can get custom axles that are 5x114 if you want to, then 5x114 wheels will fit and you'll be unique.
Old Nov 8, 2008 | 07:59 PM
The Russian's Avatar
that is actually incorrect... its a little more weird than that... hope this helps
4 Lug Pattern Measure from the center of the first lug to the center of the third lug in the pattern.
5 Lug Pattern Measure from the back of the first lug to the center of the third lug in the pattern.
6 Lug Pattern Measure from the center of the first lug to the center of the fourth lug in the pattern.
Old Nov 8, 2008 | 10:05 PM
The Russian ^^^ this is good to know
sorry for the miss info, for 5 holes: the radius R = D/(2*sin(36)) where D == 5xD
but the point is that the second number determines the radius of the circle on which the center of the bolts lie
Old Nov 8, 2008 | 10:11 PM
thepirate's Avatar
you can buy adapters to make those lug patterns fit. a guy over on vortex has some corvette sawblades on his car and he is running adapters. just a thought.
Old Nov 8, 2008 | 10:15 PM
Audi_Skydiver's Avatar
Or you can have them re-drilled.
josh
