Maintenace suggestions
Old Feb 26, 2012 | 07:49 AM
allTRACway's Avatar
the wine from your power stearing pump is normal when you turn the wheel all the way to lock (turned till it wont turn anymore).
Old Feb 26, 2012 | 09:06 AM
jonbonesjones's Avatar
Moderator
Originally Posted by morpheous
which kit are you referring too? there are several on that page,give the name and price,so i know which one to get.
well they all fit. I got the cheapest one? the one in the 250 range not the 600 kits.
Old Feb 26, 2012 | 08:21 PM
morpheous's Avatar
Oh,i didn't know that the high pitch whine was normal.
Thanks
Old Feb 26, 2012 | 08:22 PM
morpheous's Avatar
I see...thanks a lot jonesy...
Old Feb 26, 2012 | 08:54 PM
bshusted's Avatar
I wouldn't say that the noise is normal. My pump makes no noise on full lock. You should still check the fluid level.
Old Feb 27, 2012 | 01:35 AM
morpheous's Avatar
I'll check the brake fluid level too,could it be the power steering belt making that noise?
Old Feb 27, 2012 | 09:07 AM
bshusted's Avatar
All of the accessories are actually only run by one belt. If it is slipping, there are other problems that need to be addressed.
Old Feb 27, 2012 | 01:28 PM
  #18
morpheous's Avatar
Oh,alright then...i don't think it's slipping but then again,I'm just drawing straws.
Old Feb 28, 2012 | 04:15 AM
  #19
ou2mame's Avatar
its its slipping, it'll get pretty worn quick.. there's a tensioner on the front of the engine, if the bearing went bad you'll know it sounds like crap.
Old Feb 28, 2012 | 02:34 PM
  #20
morpheous's Avatar
well...as i stated before,i would think the noise would be constant and not just when i turn the wheel to the extreme right or left,if the belt was loose or slipping.
I actually need to try it again and see if it only happens when backing up and turning the wheel all the way to the right or left,i can't remember if that's when it happens.
I will report back with specific results.
NickBroderick
Sep 28, 2009 11:38 AM
NickBroderick
Sep 17, 2009 10:51 PM
Mosie84
Jun 17, 2007 08:14 PM
VikingLS
Apr 28, 2007 02:05 AM
audidrivers
Oct 25, 2005 05:45 PM
