Manual flywheel fits on auto crank. Is this right cuz it fits pics inside
Subscribe
Nov 22, 2010 | 05:58 PM
Ok. I bought an auto motor and was told you have to mill the snout down to fit manual flywheel. well last night I tried fitting the flywheel and it fits just fine. Am I missing something will the pilot bearing fit?
http://img146.imageshack.us/g/1122100037.jpg/
Reply
Nov 22, 2010 | 07:03 PM
Are you sure the flywheel is sitting flush onto the flange?
Reply
Nov 22, 2010 | 07:20 PM
Quote: Are you sure the flywheel is sitting flush onto the flange?
Feels flush to me. When I pull the bolts out its not like it falls I have to wiggle it off.
Reply
Nov 22, 2010 | 07:29 PM
Then it might work. You will have to try and see if a pilot bearing will fit in the center hole.
Reply
Nov 22, 2010 | 07:37 PM
Quote: Then it might work. You will have to try and see if a pilot bearing will fit in the center hole.
Im going to go try it now.
Reply
Nov 22, 2010 | 07:50 PM
It looks the same to me...
Reply
Nov 22, 2010 | 10:10 PM
Can a different sized pilot bearing be used/found? Not that this concerns me...
Reply
Nov 22, 2010 | 10:11 PM
The pilot does NOT fit. Theirs about a .263 difference.
Reply
Nov 22, 2010 | 10:49 PM
you haft to change the bearing but the transmission swap is possible theres a diy on the forums
Reply
Nov 23, 2010 | 12:28 AM
Im going to get the cranks swapped for $300.
Reply
