Mass oil leak!!!
Old Dec 14, 2010 | 02:48 AM
netoLopez's Avatar
Exclamation Mass oil leak!!!
It just started today around 8pm, i didn't hit anything, didn't mess with the drain plug. it just started leaking crazy, alrealy use a quart of oil. anybody has any suggestions on a possible cause? let me know before taking to the shop.
Old Dec 14, 2010 | 02:49 AM
netoLopez's Avatar
its a 99 1.8T auto quattro
Old Dec 14, 2010 | 08:27 AM
CCA4's Avatar
where's it leaking from?
Old Dec 14, 2010 | 10:55 AM
netoLopez's Avatar
i dont know, i see oil every where.
Old Dec 14, 2010 | 11:54 AM
dragonrage's Avatar
Use one of your best tools - your eyes - and try to figure something out. We need at least a general idea of where it's coming from. There are tons of different seals that can leak. The oil cooler and turbo (and the lines to/from the turbo) are some places that could leak a lot of oil fast. I hope none of your oil goes down the back of your engine, or if that would mess with an automatic as much as it does with a manual. Oily clutch = not good. Oily TC = ?
Old Dec 14, 2010 | 11:59 AM
CCA4's Avatar
Maybe try and clean some of it up, then put newspaper under the car and see where the most oil seems to be coming from.
Old Dec 15, 2010 | 02:45 AM
netoLopez's Avatar
its coming from around the oil filter area. i cleaned up the motor and with in a few minutes i spotted the leak. i was to to get it fixed was going to be around $150, which isn't too bad, and i also need a new belt tensioner
Old Dec 15, 2010 | 08:40 AM
CCA4's Avatar
oil cooler? tensioner for what belt?
Old Dec 17, 2010 | 02:13 AM
netoLopez's Avatar
the oil O ring
nat.ram2012
Mar 28, 2014 01:49 AM
lolo22
Apr 6, 2011 08:14 AM
inventorA6
Apr 15, 2009 06:46 AM
Flex
Jul 9, 2006 01:58 AM
