Misfire and no brakes
Old Jan 28, 2009 | 10:39 PM
i.m.maven's Avatar
Default Misfire and no brakes
Just few weeks ago, my car was idling really rough. So I pulled DTCs and it was misfire on cylinder 1 and 2. So I replaced all spark plugs and two coil packs.
Now today I had the same problem plus no brakes. WTF. I pulled DTCs again today and now it is showing misfire on cylinders 3 and 4.
OK so I need to replace two more coil packs but why no brakes? WTF is up with that?
Old Jan 28, 2009 | 11:12 PM
FASTER's Avatar
Tech Slut
its common for other coilpacks to go after you replace one(s). As for the brakes, check your fluid first. Then it could be a booster or the master cylinder.
Old Jan 28, 2009 | 11:29 PM
i.m.maven's Avatar
Well, brakes work perfect when I accelerate and at higher speed. It is only when idling rough, brake pedal feels like when car is turned off. If my car idles ok, then brakes are ok, but not when idling rough. So I would think it has nothing to do with the fluid.
Old Jan 29, 2009 | 12:05 AM
FASTER's Avatar
Tech Slut
ok well thats not even close to what you said in the original post. take care of the misfires and you should be all set.
Old Jan 29, 2009 | 12:19 AM
Tweaked's Avatar
Agreed. You have low vacuum due to misfires, so your pedal will feel weird.
On AWM and up (2001 B5, and all B6), when a coil pack goes dead, save yourself the headache and replace all 4 at the same time if they have not been previously replaced.
Russ Heinrichs
Aug 18, 2021 12:39 PM
dorkfish
May 6, 2013 09:58 AM
xxbmxlsxx
Jan 6, 2009 07:00 AM
cojo428
Aug 4, 2008 04:14 PM
