misfire or something else?
Old Mar 23, 2010 | 09:00 AM
  #51
mikekey's Avatar
Well guess what I heard today? Popping nose.
Let me ask you, does your car seem jumpy at lower RPM's because mine does and then when it revs up, it runs great since I reset it, but at lower RPM's this thing is a turd.
Wondering if I need to replace my DV valve now too.
Old Mar 23, 2010 | 12:30 PM
  #52
A4 2000's Avatar
A rough idle is usually due to a sensor problem. Which is likely the maf sensor. But the popping at wot with hesitation I'm assuming is the DV. I'm almost sure of this. I can do half throttle and boost fine, but at wot is when the problem starts.
Old Mar 23, 2010 | 04:03 PM
  #53
mikekey's Avatar
Alright, I'm hoping someone can explain this weirdness, or maybe it's simple.
I cleaned out the MAF today and decided, what the heck, I left the MAF and the air filter out of the car to drive down my street, and the car SCARED ME, literally I was startled by how unbelievably more powerful the car felt.
WTF?
Maybe I've got a bad maf, or what.... but is this like normal.
Old Mar 23, 2010 | 09:16 PM
  #54
A4 2000's Avatar
WTF?
Ha ha. Don't get too excited. Running with no maf sensor will cause the car to run like crap very quickly. At idle, the rpm's will jump around like crazy and the engine will just shut off. The engine will also struggle to return to idle every time you come to a stop and will pretty much turn off every time. You should put everything back asap. See about getting a new DV and see if that helps your situation out
Old Mar 24, 2010 | 12:53 PM
  #55
mikekey's Avatar
Not according to Mike, and my experience today after driving 150 miles with no maf has been amazing.
Originally Posted by Mike-2ptzero
Since you are a 2001 it wont be as bad running without a Maf, but it will throw off how much adv timing the ecu runs since the ecu is used to tell the ecu how much load there is. The ecu also use the maf to figure out how much fuel to use, but since you are a 2001 it mainly uses the 02 sensor.
Well guys, all I can say is I must have a problem with my MAF, the car is faster, idles smoother, runs better and the mileage is even better with than with the MAF. Before the car idled at 2000 RPM and now 1200RPM nice and smooth, it also pulls through the whole power band. Ever gear has power. Unlike before, where my car felt like a brick 99% of the time.
I just drove the crap out of it. So I'm going to wait to for it cool off, plug my MAF back in and if it runs like crap again, then I guess I need a new one.
A matter of fact I was really disappointed that I was getting bet by civics and scions, and two I blew away two civics and an eclipse.
It's like a whole other car. You're just going to have to believe me.
So I'm assuming that right now I've located my problem, bad MAF sensor.
Old Mar 24, 2010 | 03:00 PM
  #56
joenelson7687's Avatar
Old Mar 25, 2010 | 02:39 AM
  #57
A4 2000's Avatar
That's awesome then. I guess there's a really big difference with 2001 b5's. The driveability is zero with no maf on my 2000. Oh and guess what, I got a flashing cel today. So it is a damn misfire! It took this long for it to studder bad enough to make it finally pop up. Hopefully its just one coil pack. I'll check the code tomorrow.
Old Mar 25, 2010 | 10:49 AM
  #58
A4 2000's Avatar
I just checked it and it said a misfire was detected in cylinder #4. So I guess I'll be ordering a new coil pack and call it a day.
Russ Heinrichs
Aug 18, 2021 12:39 PM
dorkfish
May 6, 2013 09:58 AM
slow_key
Sep 23, 2010 08:25 AM
themahr
Mar 31, 2009 03:50 PM
