Misfiring Problem (2001 1.8T) Not plugs or Coil Packs HELP!!!
Sorry I'm trying to gather more info as to what your problem may be.
The battery should drop when starting so that sounds ok. (not sure what the EXACT voltages should be but 12 and 8 sound right)
Does it have compression?
You need compression, spark, oxygen, and fuel.
If you're sure there's good compression, you're getting fuel to the cylinders, and oxygen to the cylinders, then there is indeed no spark. Something in the electrical system is not getting a spark to the plugs.
