Motor Mount Install
Old Sep 20, 2016 | 06:27 PM
elduderino200's Avatar
If you haven't finished, or want to go back... evidently it's wise to idle the car a bit before you tighten the nuts down so it settles correctly into place and doesn't put undo stress on the mounts. Then tighten everything.
I didn't do this when I did my mounts and everything has been running fine for 4k+ miles. Granted the above is to help them from failing early, not immediately. It's best practice but not absolutely critical.
Old Sep 21, 2016 | 10:35 AM
ProfileTrader's Avatar
Thanks for the reminder.. I did leave the bottom nuts loose as the top of the mount is fixed into two grooves I figured it wouldn't shift much loose or tightened.
Dads Ride
Aug 25, 2010 08:47 AM
edrocks3
Dec 9, 2008 10:11 AM
savagebeast
Jun 19, 2008 08:20 AM
audiboyy
Jan 22, 2008 11:34 PM
milo55041
Oct 24, 2007 02:42 PM
