My car is on the side of the road in the middle of nowhere
Old Feb 6, 2009 | 03:55 AM
gondiguy's Avatar
Default My car is on the side of the road in the middle of nowhere
My car broke down tonight on the way home from work. I drive from Vail, Co to Leadville, Co. It is HWY 24 37 miles starting at 8150 ending up at 10,200 in elevation. 2 mountain passes and no cell service at all. I have know idea what is going on. I down shifted to 4th to slow down for a turn. I never hit gas while in 4th. Up shifted to 5th and when I pressed the gas I started slowing down. I down shifted to 4th and still no power. I pulled over to a stop and tried to start from 1st. Nothing. I started rolling backwards and pulled the e brake. The brakes don't work. I tried restarting the car and It would not start. Volts were fine but in made no attempt to crank over. The "push clutch peddle to start" was anouciated on the display. I just had my clutch replace 16 days ago. A state trooper came buy after about 5 min of trouble shooting and I had to take a ride home. HELP
Old Feb 6, 2009 | 04:22 AM
Siena's Avatar
^^^ You don't give enough information.
Model, engine type and year would be a great help.
Old Feb 6, 2009 | 04:37 AM
JDS1985_B7's Avatar
Maybe he was still upset... or doing it from his phone in the backseat of the state troopers car
Old Feb 6, 2009 | 04:40 AM
Siena's Avatar
Wink
Hey, that's evil!
Old Feb 6, 2009 | 09:08 AM
hiwords's Avatar
so your car doesn't start and your brakes don't work? check your brake fluid first to see if you have any left. i'd fix the brake first though
Old Feb 6, 2009 | 09:16 AM
somebody5788's Avatar
brakes are going to be because the engine wasn't running I believe.
Old Feb 6, 2009 | 10:14 AM
gondiguy's Avatar
2000 a4 1.8T The loss of brakes and steering is due to fact there is no power... Sorry I had to get some sleep. On the case.
Old Feb 6, 2009 | 11:59 AM
FASTER's Avatar
Tech Slut
Did you run out of gas? I know it sounds stupid, but i've heard of dumber things.
Old Feb 6, 2009 | 12:09 PM
jeffha4's Avatar
Hmm, that gives me an interesting thought. Maybe your FPR is shot or something, and not providing enough juice to give power, because from sound of it you were still running by the time you pulled over. And then wouldn't start after. So maybe that could be it?
Old Feb 6, 2009 | 06:11 PM
Tweaked's Avatar
Any lights? MIL? Battery voltage?
Mechanically, you could have a bad clutch slave, but that wouldn't cause the engine to not crank. It sounds like something more like a bad alternator or battery.
If you ran out of gas or had a fuel delivery issue, you'd still be able to crank the engine over... it just wouldn't catch.
masarkar
Aug 12, 2013 10:22 PM
4plaay
Feb 14, 2010 01:25 PM
rocklob0
Jul 19, 2009 03:22 PM
JDanielT
May 28, 2008 12:09 AM
BlackRaptor
May 14, 2007 12:53 PM
