my cats keep blowing
Old May 13, 2013 | 09:21 PM
Expplucky's Avatar
Default my cats keep blowing
I'm getting misfie codes for all Cylinders on the driver side, and the catalytic converter blew on that side aswell just replaced it 2 weeks ago and haven't even drivn it because of the misfires. Wtf?
Old May 14, 2013 | 08:14 AM
CCA4's Avatar
If I had to guess, I would say that the cat asploded because of the misfires, not the other way around. Driver's side is Bank 2 IIRC, sounds like your coil pack might be taking a ****. How do your plugs look on that side? Any oil on them? Are the tops of the pistons wet? I assume you scanned the car, can you post up the full print out of the codes?
Old May 14, 2013 | 04:03 PM
jeckel20003's Avatar
Coil pack provides power for two cylinders per coil. Each coil provides power to one cylinder on each bank. So if a coil was bad I would think you would be getting more than just misfires on one side.
Old May 15, 2013 | 03:09 PM
Expplucky's Avatar
ya i tested the coil pack and im getting white spark.....the plugs arent covered in oil, my guess after narrowing down a few things is the cam position sensor, would this cause a misfire so bad as to blow out my cats?
Old May 15, 2013 | 05:08 PM
Mad Cow's Avatar
Has the timing been messed with recently? I almost bought a 30v motor that looked mint, except one bank had perfect compression and the other had zero, guess what the cause was. You could try swapping the cam sensors, it's a 5 minute job and at least it'll rule that out. But most likely it's not that because there's really nothing there that can go wrong with the cam sensor, generally it either works or it doesn't with no kinda working stage.
Old May 15, 2013 | 05:13 PM
Do you have any way to scan the car for codes? I had one a while back that said I had a bad cam position sensor. I replaced it and the code never came back. My car wasn't showing any signs of having a problem though. You could try switching cam position sensors between the two banks and see if the problem moves to the other bank. Although if that is causing you to blow a cat you might blow the other cat as well. The passenger's side is on the front behind the upper timing belt cover. The driver's side is on the back of the engine. You don't have to remove much to get at the driver's side.
Old May 15, 2013 | 05:41 PM
Expplucky's Avatar
ya just changed the T-belt a a couple weeks ago, im pretty sure i have to put the car back in the service position to swap cam sensors,
but im waiting on my vag cable should be here today but i guess shipping quotes in china dont mean dick in the U.S.
Old May 15, 2013 | 10:52 PM
Mad Cow's Avatar
You definitely don't need service position, they're right there under the top cover, just go out and look. Check the physical timing marks on the cams at least, maybe they're off a bit.
Old May 16, 2013 | 10:19 AM
Just remove the top timing belt cover and it's right there. Take out the two bolts that #1 is pointing at.
Old May 16, 2013 | 03:47 PM
Expplucky's Avatar
awesome thanks guys im guna give it a shot. Im guna post my vcds results tonight.
vtraudt
Jan 10, 2014 11:27 PM
BLS
Dec 12, 2011 03:33 PM
derek072887
Jun 12, 2008 12:07 PM
chosos
Apr 22, 2008 06:53 PM
Hecareth
Apr 19, 2008 12:24 AM
