My very own update thread
Old Jul 9, 2013 | 02:23 AM
  #261
redline380's Avatar
Legal Moderator
you had trouble with the bumper? i thought it was very easy to take off. first time i had it off in less then 30 minutes.
as for turning the engine over with the tranny in gear, dont worry about it. the engine puts out plenty more torque than you are capable of.
Old Jul 9, 2013 | 02:48 AM
  #262
BaseDrifter's Avatar
Site Moderator/B5 Tech Guru
Yep, couldn't get those clips to let loose for the life of me. The trick eludes me.
Yeah thats what I was thinkin' haha.
Gonna go tear the TIP and DV apart now and check the waste gate. Tomorrow I'm planning to pop the cat off to inspect the waste gate flap, which I think is the source of my lost 3psi.
Old Jul 10, 2013 | 03:18 PM
  #263
VC removed.
Some cam lobe wear...
Timing components removed.
Intermediate shaft seal removed.
Crank pulley off.
In the process of removing the crank seal.
Crank seal removed.
New crank seal installed (worried about the seal depth, looking into it.)
Old Jul 11, 2013 | 01:13 AM
  #264
Buttoned up the top end today after installing the CCT. First time taking the cam out was a little nerve racking but it seems to have gone smoothly. We'll see when I start the motor!
I've been following the Bentley procedures as much as possible and torquing everything appropriately. Cam cap locations and directions were noted, oiled, and torqued in the proper order. Tomorrow I'll be picking up a new crank bolt. Figured an $11 bolt is better than a new motor...
Cam chain tensioner tool installed.
Double cam bearing cap removed.
Sprocket bearing cap removed.
Exhaust cam and CCT removed.
Exhaust lifters.
Cam reinstalled with new CCT.
New cam seals installed.
Old Jul 11, 2013 | 09:16 PM
  #265
Got almost everything hooked back up. Timing belt is on, everything is lined up, tensioned up, torqued, double checked, rotated a few times, no scary noises present..should be good to go. I'm about ready to put the carrier back in place and do a coolant flush.
Old Jul 12, 2013 | 03:16 AM
  #266
She's purring nicely. Started up fine, all vital signs look good.
Old Jul 12, 2013 | 04:11 AM
  #267
redline380's Avatar
Legal Moderator
Thumbs up
looking good
Old Jul 12, 2013 | 09:45 PM
  #268
looking good
Thanks, everything is still sitting pretty. No leaks. Got it all buttoned up today and took her for a spin, sounds great.
I also picked up a genuine vag com cable and was able to program the correct mileage into my new LCD cluster and finally finish that project!
Old Jul 15, 2013 | 06:40 PM
  #269
I decided to add up the money I've put into this car to give me an estimate of where I stand. I'm sure I'm missing a few things but this should be close.
Old Jul 15, 2013 | 08:15 PM
  #270
B5 Audi's Avatar
did you have the turbo and control arms done at a shop/dealer those prices seem pretty high. really clean bay though.
