Need to Change my vss is this a possibility?
Old Apr 24, 2013 | 03:30 PM
GusTaVz_a4's Avatar
Default Need to Change my vss is this a possibility?
so i was searching online to see if anyone had a diy on changing your vss, now i read online that i would have to remove the wheel and go in blind through the hole that is for the axle, it seems that this youtube way is a lot easier, i was wondering if this would be possible on my 2.8 because the engine is a lot bigger hmmm, any feedback would be appreciated...
Old Apr 24, 2013 | 10:51 PM
redline380's Avatar
Legal Moderator
It depends of you have a manual or auto. I believe they are in different spots. Either way it is very doable
Old Apr 25, 2013 | 10:58 AM
Mad Cow's Avatar
No way are you going to reach down there with a v6, just pop the hood and try to reach the axle yourself.
Old Apr 24, 2015 | 04:15 PM
jmquinn72's Avatar
Old post, I'm assuming you eventually tackled this. I found this same video, but it appears this won't work with the 2.8L V6.
When I crawled underneath to find it before I'd researched this I did find the VSS, but deduced the wheel would have to come off for access.
I wasn't sure what you meant about going in "blind" though. Do you not have physical access and/or eyes on the VSS after removing the wheel?
jonbonesjones
May 5, 2012 11:40 AM
jbh-A6
May 31, 2011 04:28 AM
auditamer
Feb 12, 2010 10:40 PM
00Audi180Q
Sep 29, 2008 08:01 PM
betz470
Oct 15, 2005 01:31 AM
