Need help
Old May 18, 2010 | 02:25 AM
RichardCVan's Avatar
Default Need help
I got a 2001 Audi A4 1.8T Quattro with 124k miles, I am about to do a spark plug change but dont know which one i should get and how many of them. I am also wondering how can i get a better Gas mileage, everytime i drive the car its showing 9.8-22MPG on the LED display.
Old May 18, 2010 | 08:47 AM
turbo kraut's Avatar
Tech Guru
you need 4 plugs and just get stock replacement, since you are stock....
don't follow that display if is an average
Old May 18, 2010 | 01:50 PM
where is the spark plugs at?
Old May 18, 2010 | 02:13 PM
Tech Guru
under the 4 pushdowns(coil packs)
Old May 18, 2010 | 08:01 PM
5Speedwtneed's Avatar
yeah. its a 5mm allen head. two per coil pack. its a 5/8 spark plug socket i think. I would just use the NGK iridium that comes in the car. and i dont see it necessary to unplug the coil packs. just the little ribbed tabs holding down the wires.
Old May 27, 2010 | 02:03 PM
i just changed the cabin filter for a tune up.. next is spark plugs from advance auto parts.. any suggestions?
Old May 27, 2010 | 03:57 PM
bradtyler02's Avatar
Walk in, tell them you need NGK spark plug for an '01 Audi A4 1.8T. Take the ones they give you (only a couple bucks each) and go install them. (You only need 4 of them).
Since you're tuning up, might as well change the oil if it's been a while (synthetic, of course) and check your air filter.
124K miles, might also be time for a new Timing Belt. Do you know when the last time it was changed? This is a little more in depth than a "tune up" but is some critical maintenance that can't be ignored.
Old May 27, 2010 | 05:17 PM
they have NGK for 9 bucks is that the one?
Old May 28, 2010 | 03:26 PM
any idea where the MAF sensor is? i need to clean that out
Old May 28, 2010 | 06:25 PM
hiwords's Avatar
you need to get yourself a repair manual. bentley makes a really good one. it'll tell you where things are with pictures and give you a how-to. your MAF is inside your airbox. make sure you use MAF or electronic cleaner or you'll damage the MAF
