Need help! 99.5 audi a4 rough idle loss of power
Old May 1, 2011 | 06:31 PM
AWD_Addict's Avatar
Default Need help! 99.5 audi a4 rough idle loss of power
I recently bought my second audi a4. Its a 99.5 audi a4 1.8t quattro. My problem is when i start the car it has a rough idle between 800-1000. If im in 1st from a dead stop the car has soooo little acceleration and after about 2500rpm itll accelerat faster/normal? I am new to the 1.8t motor. im not getting any codes and my engine light is off. Any help would be greatly appreciated.
Old May 1, 2011 | 07:51 PM
audiltr's Avatar
i would start buy checking your plugs ex. condtion, gap,
Old May 1, 2011 | 08:03 PM
AWD_Addict's Avatar
My spark plugs are gapped at .35, which i should regap them to .32?? and what auto parts store carries NGK plugs? Autozone doesnt carry NGK nor bosch
Old May 1, 2011 | 10:17 PM
ImTheDevil's Avatar
You want .032" gap and mine came from Advance. Check your vacuum hoses for leaks/splits/rot as well.
Old May 1, 2011 | 10:32 PM
AWD_Addict's Avatar
Awesome I'll pick some up tomorrow and see if that rectifies the problem or not. Also I can't find the right size bulbs for my back interior lights and the front. They're small and push/twist in. They're not the ones with two pieces of metal on either side of the bulb. Any ideas? And thanks for all the help guys I really appreciate it
Old May 2, 2011 | 01:04 AM
mobitsfa's Avatar
Hey I have sort of the same problem. I don't have a rough idle, but more vibration than normal, and it's pretty sluggish taking off in first compared to a 1.8t jetta. I just bought it yesterday it's a 98 a4 quattro.
If you have any vibration here's a thread to fix it:
https://www.audiforums.com/forum/sho...d.php?t=132012
I'm going to try everything mentioned. Also, is your gas pedal hard to push? Mine is, I'm going to clean out the throttle body and check the accel cable, maybe replace it. I'll probably do a seafoam run.
I'm changing out the coil packs and spark plugs too.
I'll update here if anything improves...
Dooley12
Feb 23, 2014 04:47 PM
drewcafua
Aug 13, 2012 10:07 AM
troysherk
Jul 11, 2012 12:38 AM
rescuer3
Oct 10, 2009 01:22 AM
doomwalrus
May 9, 2009 11:37 AM
