Need help asap
Old Nov 11, 2012 | 05:39 AM
Subarashī Kao's Avatar
Default Need help asap
so guys today on my way home my car keeps on blowing the hose from the TB to the SMIC off when its under load like punching it to the floor and as soon as i let go of the accelerator the hose pops out. i just got my pc16 file and pulls crazy good but as soon as there is a big load and i change gears boom hose comes out, i also feel like this hesitation at high rpms right before it pops it out.
am thinking maybe dv valve not opening right or its to tight? i have a adjustable Dv with the little screw on the top , i have it basically default which is as lose as possible but not super lose.
Old Nov 12, 2012 | 06:31 AM
CCA4's Avatar
You need to make sure the inlet on the intercooler and the inside of the throttle body hose are both very clean and dry. Tighten the **** out of the hose clamp and it shouldn't pop off.
Old Nov 13, 2012 | 05:48 AM
yea i did that and i found out what it was the hose that runs from the manifold to the DV/bov had a hole it melted from touching metal had to replace and heat wrap now it does not blow the house out.
as for my hesitation problem at high rpms well it was my spark plugs the gap was set at .45 autozone says that they are .40 oem i then set them at .28 and ran like a champ at high rpms but suck so bad at idle it well misfire and i got check engine light, i then regap them to .40 and so far this has worked the best but still a little hesitation but then again am using some random *** spark plugs that dont belong on that audi gotta buy the oem or better replacement lol, and i gotta get rid of that stupid catalytic that restricts my power at high end so bad.
Old Nov 13, 2012 | 07:59 PM
mtroxel's Avatar
Tighten the **** out of the hose clamp....
My torque wrench doesn't have a reading like that.........where can I buy the proper too?
Old Nov 14, 2012 | 12:11 AM
crazyquik22023's Avatar
Hose clamps don't have a torque spec.. He was obviously just saying make sure all the clamps are tightened down good.
Old Nov 14, 2012 | 05:40 AM
yea they are right those clamps need to be tight i got rid of the cheap claps the car comes with and when with those heavy duty ones with lock they work like a charm no more sliding out.
Old Nov 14, 2012 | 10:16 AM
CCA4's Avatar
Tighten it until the bolt snaps off, then back it off half a turn
Old Nov 15, 2012 | 08:39 AM
mtroxel's Avatar
Thanks Crazy, but I was just being sarcastic.
Ahhhh....so do you call that torque to yield?
On bolts where it's really impractical to get a T wrench on 'em, I've always gone to PDT (Pretty damn tight).
Old Nov 15, 2012 | 08:51 AM
CCA4's Avatar
That's what I did with the caliper carrier bolts when I did my brake upgrade. My torque wrench is too long to fit in there so I just put some locktite on the bolts and tightened them until I was happy. That was two years ago
Mmspartan
Jun 14, 2011 05:14 PM
zerodegre
Sep 20, 2009 11:33 PM
dejahn23
Sep 22, 2008 07:28 PM
bhunt17
Feb 21, 2008 07:07 AM
silveraudib6
Feb 8, 2008 04:11 PM
