need help with headlights
Old Dec 21, 2011 | 11:56 AM
A4driver17's Avatar
Default need help with headlights
so i bought brand new one piece headlights but they didnt come with the blinker housing thing. I have to buy a brand new one because the one that was on mine was super glued to the blinker assembly and i had to break it...so my questions are
1. what is the thing called that holds the blinker light and is hooked to the wires
2. where in the heck do i get one?? i just the the light housing that holds the blinker bulb so i can hook it up to the wires
BTW the picture is what i seen when i looked at the light for the first time. The piece with electric tape around it is what i need....
Old Dec 21, 2011 | 12:30 PM
CCA4's Avatar
I believe this is what you need, but thats not exactly a bargain. I would say your best bet to get it cheaper is a junk yard.
Old Dec 21, 2011 | 02:49 PM
A4driver17's Avatar
That would be perfect if it was for the 2.8 that looks completely different than the 2.8 socket
Old Dec 21, 2011 | 03:09 PM
Skythe's Avatar
I ran into this when I bought 1-piece headlights for my prefacelift B5. The connector that Chris linked you to is for facelifted models. I'm assuming you have a prefacelift based on your user profile. The prefacelift piece is designed differently than the updated one but they both twist/snap into the headlight housings the same way. The ones you should have on your new housings will twist out and you can twist a prefacelift version into it's place. You can definitely find the piece at a junkyard.
Old Dec 21, 2011 | 03:11 PM
DOC_DEPALMA's Avatar
Something I do is find the part number on ECS and try googling it for the cheapest price, depending on the part of course. Also, rockauto.com is a good spot to look too
Old Dec 21, 2011 | 03:17 PM
Skythe's Avatar
Volkswagen Passat B5 FWD 1.8T > Lighting > Indicator > ES#257087 Turn Signal Socket - Priced Each - 3B0953123A
haha I can't believe I found that! As you can see they're going to sell you a used and dirty part for $23.18 plus shipping and handling. Most junk yard B5's (Audi and VW) around here are prefacelift and have the lights still on them.
It says VW Passat, but the parts are identical and it doesn't matter what engine or drivetrain the car is
Old Dec 21, 2011 | 09:17 PM
A4driver17's Avatar
Those are all awesome but that still looks nothing like the one i have...it doesnt even look like itll fit =\ i dont wanna buy soemthing then get it and its not even the right thing....
Old Dec 21, 2011 | 11:20 PM
Skythe's Avatar
Unless your headlights are completely different, I'm pretty sure that's it. Try comparing the picture to the other side that you do have and/or post up more pictures
Old Dec 22, 2011 | 05:05 AM
A4driver17's Avatar
Ok so i looked at it and that looks pretty much like it lol. I guess i wasnt paying close attention to it. Sorry guys =\ thanks for the help. I do believe this was the fix.
PSULion21
Mar 18, 2012 11:28 PM
ashulga
May 7, 2010 03:40 PM
ashulga
May 7, 2010 02:56 PM
A62dot7turbo
Jun 27, 2009 10:17 AM
mschwister12
Feb 4, 2008 11:40 PM
