Need Help: Oil Change, Drain plug question
I can not seem to find the oil drain plug on my 99 Audi A4 1.8t. This is my first oil change since I got the car a month ago. I looked at some audi pictures and it should like this:
But mine looks like this and there is no drain plug???
however there is a plug on the other side (Driver's side left side) but it doesn't really look like it was used before, so i didn't want to open it without first asking you guys.
Please help to clarify where is my drain plug here? Any help is appreciated. Thanks.
I wasn't sure if you were kidding or not... The thing that got me confused it on http://www.fastaudi.net/a4/index.html that person has the same exact car and engine but I don't have the drain plug that he has on the picture I posted earlier...
Where is the drain plug on Audi A4 1.8t quattro? I don't have the owner's manual
No I meant it in the first post because it looked like an oil drain, but after Techbod posted, I looked again and it looks like he's right - not to mention, he IS an Audi tech and knows far more than I do - I'd defer to him in pretty much any given situation.
ORIGINAL: techbod
that is definatly not the oil drain plug more like the air con[:-] whatch what your doing?
that's the oil drain plug
quick edit: the first picture is deceptive because I see 3 different things and that 19mm bolt on that side doesn't look like its for oil drain, other things are AC/power-steering pipes because that's how they are made, the one going into the sump could be oil return or vent
[IMG]local://upfiles/12092/BF1C44F142F44796AE53F7096D68F731.jpg[/IMG]
ORIGINAL: AK_47
Now... did you find out how to get the filter out without turning your subframe into a catch-pan?
