Need Help Water Pump Belt!
Old Jul 11, 2010 | 05:33 PM
jason7467's Avatar
Default Need Help Water Pump Belt!
My belt that goes around my ac condenssor and the water pump snapped on my way out of town. My car is on the side of the road and I am trying to avoid a tow. I know if I had the car at home I could pull apart the front end and repace the belt but, is there a quick way to replace the belt on the side of the road, eliminating the cost of a tow? It is not the timing belt or the belt that goes around the power steering.
Old Jul 11, 2010 | 05:38 PM
Tourbo24's Avatar
well i have the 2.8 engine and the timing belt goes around the water pump...
i dont know about the 1.8t engines, is that what you have?
Old Jul 11, 2010 | 05:42 PM
jason7467's Avatar
I have the 1.8 and the timing belt doen not go around the water pump. I have three belts on the front and nothing else goes around the water pump so it gives me hope that there might be a way of getting to this without disassembling the whole front end
Old Jul 11, 2010 | 05:46 PM
FASTER's Avatar
Tech Slut
What year is the car?
Old Jul 11, 2010 | 05:48 PM
jason7467's Avatar
98 1.8t quattro
Old Jul 11, 2010 | 05:53 PM
FASTER's Avatar
Tech Slut
Is the belt on the passenger side or driver, cuz the wp and ac are most defintly not run by the same belt on that engine.
Old Jul 11, 2010 | 05:58 PM
jason7467's Avatar
here is a pic and its the belt on the right which would be drivers side. It is the belt that goes around the power steering and the water pump. My question is can you take off or loosen the water pump pulley without taking apart the front end?
Old Jul 11, 2010 | 05:59 PM
FASTER's Avatar
Tech Slut
Here's a pic of my car with your engine with the ac removed. As you can see it was on its own belt. So which belt are you talking about.
Old Jul 11, 2010 | 06:04 PM
FASTER's Avatar
Tech Slut
Ok no you'll need to take off the front clip. That belt tensions by putting the 2piece pulley back together and tightening it up.
Old Jul 11, 2010 | 06:13 PM
jason7467's Avatar
That blows stupid Audis and their stupid designs! Ok well thanks for the help I guess ill call in a tow.
Thanks
