Need to replace rear speakers
the speakers in the back (behind the seats) are blown and rattle
amazon is having a good sale on rockford fosgates..which ones would i need? also, how much would installation cost?
http://slickdeals.net/forums/showthread.php?t=2133234
thanks
thanks
Either way, I think each speaker has it's own amp and is a pita to replace without wiring a new aftermarket amp in. As long as its just a tear and it hasn't crumbled to peices, you could still glue it back together. One little blown speaker could mean an investment in a whole new system if you arent careful... Unless thats what you're going for.
your stock amp (under the driverside rear speaker) won't work with your aftermarket speakers, the rears are run by that amp, and the fronts are run by the deck. you can fit 6.5s in the rear deck without cutting
AmadiAudiA4
Aug 15, 2008 11:31 PM
