New to 1.8T
Old Oct 15, 2014 | 06:36 PM
  #101
adam044's Avatar
Originally Posted by greenmtrider
OH ya one other thing tonight I cleaned my spark plugs and cleaned out my air box(found old mouse house). I am guessing the dealer that I purchased the car from never even looked.
Just buy new spark plugs, why spend time cleaning them? Nothing beats new spark plugs.
Old Oct 16, 2014 | 07:38 AM
  #102
greenmtrider's Avatar
You are correct, it was a late night and I was looking for some thing to do. I ordered new coil packs and plugs.
Old Oct 16, 2014 | 07:44 AM
  #103
Ok so I goofed a little, the RPM surging only does it while the transmission is in drive. So factor in the out side temp, engine temp and now a load on the engine. I can be sure of one thing the colder the out side temp the more surging I get. As soon as the temp needle moves the surging goes away.
Old Oct 16, 2014 | 08:35 PM
  #104
adam044's Avatar
Good call
Old Nov 9, 2014 | 08:01 AM
  #105
Ok unemployed sucks, all work on the A4 has come to a hault Since Union went on strike I must have washed and waxed a dozen times. Of course this is in between job searching. It might be time to leave New England. I am still looking for answers on the RPM surging issue.
Old Apr 12, 2015 | 07:17 AM
  #106
Have been back to work now for 2 months feels great. Sorry I have not posted anything since then, the A4 is running great. I have been surfing around this weekend to see what kind of money should be spent first. The short list, front bearings, transmission service, dreaded timing belt. I would also like to try the PCV revamp this summer. Saturday I spent 5 hours washing, claying, waxing, rubbing compound on the lowers. Cleaning carpets, leather etc.
Old May 9, 2015 | 07:00 PM
  #107
The troubles with my B7 are starting to add up. Wheel bearings are needed, 99,342 miles this means timing belt change, BSH PCV needed, changed spark plugs found oil in the #4 spark plug whole. But here is something strange, the oil is cleaner than that in the sump. So no mods just repairs and keep it reliable.
Old May 9, 2015 | 07:09 PM
  #108
I love my B7 also needs a Trans service, diff"s serviced. As some people say when do you say when. Yes it's no where near perfect.
Old May 25, 2015 | 06:23 PM
  #109
kjmcdowell77's Avatar
Default 1.8 cold miss fire
I have a misfire on initial start up but it goes away after about 10 seconds. I'm thinking my #2 injector is not holding pressure and flooding the cylinder. after 10 seconds or so, it is fine and runs great. It only has to sit for about a half hour or 45 minutes for the problem to recur. If I let it set for 36-48 hours, the problem often will not surface at all. It is an 02 B5 with 78K miles. I've run a tank of gas with BG 44K and no difference. Any other thoughts?
Old May 27, 2015 | 07:52 AM
  #110
Take your spark plugs out, are they all the same looking?. If you think you have a miss fire then Coil. Should have nothing to do with fuel pressure, if so it would effect all cylinders. Do you have any engine codes?.
