New to 1.8T
The engine code should be on a tab near the timing belt cover it will a flat machined piece off the head on the driver side front. Should read AEB AWM or ATW.
Also.. You really shouldn't get the engine bay wet with a hose chances are you got the coil packs wet and they are causing misfires. IT should clear up after a few days/heat cycles.
Jason
Jason
If you order from ECS or Blau they will ask you what engine and send you the correct belt. Where are you getting your belt and stuff?
Have not orderd one yet just saw online that there was two different tooth numbers. Jason i am haveing a tough time finding that plate, it could be because i am looking in the wrong area. Do i need to remove the timming belt cover? thanks again.
You may need to remove the plastic engine cover to see this.
Jason
Foud it it AEB engine, so what tooth belt do I need?. Also It seems like I am going through a court of oil every two weeks. Its not leaking or smokeing, it's not in my air filter, where els should I look?. Thanks for your asistance.
