new to audi
so come 2am i passed out
Ok so go to control panel WITH VAG COM CONNECTED TO PC.
-at the bottom of control panel select (view hardware and devices)
-then you should see ports (COM & LP)
-select usb serial port in tab(double click)
-select advanced in port settings
-select com port 1-4 its your choice
-change transmit/recieve bytes to 1856
-change latency timer to 7
-save and exit
-now connect cable w/ computer to obd2 and follow other instructions i gave(be sure to select same com port in VCDS you set in the device manager)
Hope this helps
-save and exit
Hope this helps
i got it to work on most of the things... still cant get it to read my abs though
but this is wat i got for my airbag light how do i fix it ??
Control Module Part Number: 8D0 959 655 M
Component and/or Version: Airbag 7 Audi 0502
Software Coding: 00104
Work Shop Code: WSC 06335
1 Faults Found:
01218 - Side Airbag Igniter; Passenger Side (N200)
32-10 - Resistance too High - Intermittent
does this have to do with the connecter under the seat ive been hearing about ?
also on a side note looks like im doing rear hub bearings tom.. i went to pull my rear brakes and notices the right rear is a junked bearing
minus another 200 from waterfest money
fronts are in and tight and done including pads and rotors
1 Faults Found:
minus another 200 from waterfest money fronts are in and tight and done including pads and rotors
the car does have a triple k turbo in it no idea witch one...
and how is this manifold i know its an ebay one but i just found a crack on the stock one i can probably have it welded up its not bad just a hair like crack but if any1 has experiance with this one let me know
http://cgi.ebay.com/ebaymotors/K03-K...item19bc6db7a2
i did reset them but i havnt been inside the car for a day or 2 ... and to be honost im pissed i bought the damn thing at this point
well on a side note i was looking for the numbers on the turbo thats how i found this garbage ko4-015/57749 so it is a ko4 but wtf is this bolt and why is it welded and look like its also leaking exhuast
and heres the crack u cant see it very well if at all stupid cellphone
Hey ther storm, Do what you can with the Vag Com, dont be upset you bought it, believe me I will be indispensable in the future, youll be able to quickly diagnose any problems w/ the engine and control modules. be sure to check the air bag connection beneath the seats sometimes they will get loose from the power seats.
