New Owner In Need Of Help!
Old Jul 2, 2010 | 09:19 PM
Mike-2ptzero's Avatar
Best thing to do is just buy a cheap test pipe, just to see if it is the cat that is the issue. You can always buy another cat later and then sell the test pipe.
Misfire in #2 cylinder usually means the ICM is going bad.
Old Jul 2, 2010 | 09:34 PM
dinkk's Avatar
what is the ICM?
Old Jul 2, 2010 | 11:43 PM
It is the thing that was mounted to a heat sink that is mounted into the top of the air box.
Old Jul 3, 2010 | 04:58 AM
dinkk's Avatar
Oh ok I was wondering what that thing was....mine was on top of my airbox but it won't go in cause the rubber thing around it is messed up and can't pop it back in....and is it this part right here looks a little different then mine since it has light grate type of deal on it.
http://www.autozone.com/autozone/par...416280_0_7036_
and if it is $159.00 seems a little steep is there anywhere else I could get one for cheaper and before I do how can I check if its bad?
sorry for all the questions its my first audi thought I got a good deal but more troubles than I thought.
Old Jul 3, 2010 | 09:55 AM
YEs that is it. You can do a google search for Audi A4 1.8t ICM.
Old Jul 6, 2010 | 02:04 PM
dinkk's Avatar
I got it, I ordered one from ebay for $51.00 Hopefully that stops the misfire. Ill update when part arrives and its on thanks!
Old Jul 6, 2010 | 02:10 PM
CCA4's Avatar
Originally Posted by bradtyler02
CCA4, I know you'll see this eventually, can I get a face palm please? I think I earned one here...
Ask and ye shall receive!
To the OP, it may be too late for this now, but i like to clear all the codes, run the car for a while and see which ones come back. Sometimes that helps to narrow down the root cause, all those lights/codes can be confusing if you try to diagnose them all at the same time.
Old Jul 6, 2010 | 04:49 PM
  #18
bradtyler02's Avatar
Thanks...
Old Jul 7, 2010 | 04:40 AM
  #19
dinkk's Avatar
yeah thats what I did erased all them car ran perfect on the way back started running rough cel came on checked it erased it and did it again. All that kept coming up was cyl 2 misfire.
Old Jul 7, 2010 | 07:15 AM
  #20
CCA4's Avatar
How are the coilpacks? Try swapping the cyl. 2 pack with one of the others, and see if the misfire follows the coilpack.
