New Timing Belt - Car Won't Start!
After installing water pump, timing belt, tensioner, drive belts, new A/C belt tensioner, I tried to start it up and it won't start!
Cranks over energetically, but won't fire.
I removed the plugs to allow turning engine over easily, plugs and coil packs are now back in, of course.
I was obsessively careful to maintain crankshaft and camshaft timing marks, turning it two crankshaft revolutions numerous times. Marks always lined up.
Car is still in service position. There are no engine codes, using a generic code reader.
Any ideas? Any reason timing belt job would result in not starting?
And, is there any detailed "car won't start" diagnostic here or elsewhere?
Many thanks.
John
Many thanks.
John
If you've turned it over by hand and using the starter, there isn't any chance that you've got valve interference.
As mtroxel stated, this probably isn't a mechanical issue. There must be something you unplugged while doing the TB that didn't get plugged back in.
It finally started after I pumped the gas, like old carburetor cars that would get "flooded."
It was very rough and there was a puff of smoke. The smoke came and went too quickly to see clearly, but it looked white or grey in the rear view.
It then smoothed out somewhat. I have to put the coolant back in and drive it around to see if it smooths out.
I wonder if turning it by hand 4 times did something to flood the engine?
This happened once before when I was not working on it. It would not start for a few minutes then started and was rough, then smoothed out.
Thank you for your help.
John
John
BTW, it's not great to start them with no coolant. You won't overheat it with 20 seconds of running with no load. But the new water pump needs coolant for lubrication.
I should have said "top off the coolant." There was as much coolant as would fit without opening the heater hose hole and running the engine to get the air out.
ericmorin
Aug 15, 2006 12:23 AM
