New tires and rims, will speedo be off
Old Dec 5, 2010 | 02:54 AM
jhanson25's Avatar
Default New tires and rims, will speedo be off
Tonight I got some 2004 stock 17" Audi rims and tires to replace my 15". How far will that throw my speedometer off? Is there a way to reset my car with the new rims and tires with my vagcom so that it will not be off? Thanks!!!
Old Dec 5, 2010 | 01:05 PM
ImTheDevil's Avatar
Depends on the tire size. Use a 225-45-17 and you'll be almost identical.
Old May 2, 2011 | 11:25 AM
MKE_Audi's Avatar
I'll ask the question, can you use vagcom to adjust for a change in tire size?
Old May 2, 2011 | 01:24 PM
krazzz's Avatar
http://www.miata.net/garage/tirecalc.html
Go to this site and enter your old tire size and the new tire size and it will tell you how much (if any) it will be off.
Old May 2, 2011 | 01:30 PM
rcheing's Avatar
No you can't. As "krazzz" said, use that url to find the most approximate size to keep same stock wheel diameter.
Old May 2, 2011 | 06:57 PM
kolbs_91's Avatar
Plus One to what krazzz posted. It's all about the rolling diameter. If the difference is small enough then you don't really need to worry. However, if the difference is large enough you might want to consider having your speedometer re-calibrated.
Vindedreal
Jul 25, 2010 06:34 PM
Walter Ribeiro
Jan 3, 2009 07:54 PM
96audia4awd
Jun 22, 2008 03:28 PM
Colin519
Nov 23, 2006 01:56 AM
wood_e
Sep 11, 2006 12:40 AM
