Newbie - Vacuum hoses to A/C
I am new to the forum and to Audi ownership. I purchased my '96 A4Q 2.8 in May and have already performed some common maintenance - with the help of my scanner and Bentley book. Most recently, I replaced the IAV after reading the code. While doing this, I realized that one of the factory vacuum hoses (which has multiple t-connectors and goes to the A/C through the fire wall) was disconnected from the nipple on the manifold.
I found the hose in the Bentley book, but I am not sure if I need to buy a replacement hose from Audi or if I can make one myself with splitters. I found the depiction under the Vacuum connections for Fuel Injection and Ignition.
Any ideas? If I can make it myself, are there any suggestions on the type of hose.
Thanks in advance,
'96 A4
2.8 Quattro
Thanks in advance,
'96 A4
2.8 Quattro
Thanks, that does help. The OEM is hard plastic with a sheating over it. Based on what I have seen in my service manual it also ties into a check valve pre EGR valve. Since it hits different end points and valves all behind the engine next to the fire-wall, I did not know if I need to buy something from the dealer and get hosed on cost.
